주요 콘텐츠로 건너뛰기
LG V20 Battery Replacement
필요한 것
  1. LG V20 Battery Replacement, Back Cover: 1 단계, 이미지 1/3 LG V20 Battery Replacement, Back Cover: 1 단계, 이미지 2/3 LG V20 Battery Replacement, Back Cover: 1 단계, 이미지 3/3
    • Press the button on the lower right side of the LG V20 to open the clamp that holds the back cover on the back side of the phone.
    • Remove the back cover.
  2. LG V20 Battery Replacement, Battery: 2 단계, 이미지 1/3 LG V20 Battery Replacement, Battery: 2 단계, 이미지 2/3 LG V20 Battery Replacement, Battery: 2 단계, 이미지 3/3
    • Before disassembling your phone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Insert a spudger or your fingernail under the battery at the small recess on the lower edge.
    • Be careful not to deform or puncture the battery.
    • Pry up and remove the battery.
결론
For optimal performance and to avoid software sided errors, calibrate your newly installed battery: Drain battery below 10%, then charge uninterrupted to 100%.
다른 10명이 해당 안내서를 완성하였습니다.
Garrett Janney
회원 가입일: 04/26/17
897 평판
안내서 4개 작성하였습니다
Cal Poly, Team S22-G5, Livingston Spring 2017 Cal Poly, Team S22-G5, Livingston Spring 2017 회원
CPSU-LIVINGSTON-S17S22G5
4 회원들
안내서 36개 작성하였습니다
댓글 3개
Is this battery the same quality or a least pretty close to the OEM battery of the LG v20?
Allen Wong - 답글
Don’t buy this battery. It looks like an OEM but it’s not. That’s fine but I’ve had this for a couple months and it quickly discharges now. I’ve gone back to my original for the time being.
The only reason why I purchased it from here was the company which I have mad respect for. But this issue isn’t their problem and we’re talking about an old phone which LG doesn’t even make batteries for. People will still come here since it’s the last phone with easy access to the battery and it’s just a great budget phone!
Kenneth Shin - 답글
Just charged my new battery up from ifixit store. Sooo much better then my old one. (4 years old.)
Will update if there’s been an issue with it within the first year or two if i remember (i mean to.).
Happy repairing everyone!
RxMode - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 13
30일 전: 72
전체 시간: 9,097
