소개
Tried to take a selfie but can't focus in on the shot? This may be because your front-facing camera is damaged and needs replacement. This guide will walk you through the steps of replacing the front-facing camera of your LG V20.
필요한 것
Insert a spudger or your fingernail under the battery at the small recess on the lower edge.
Be careful not to deform or puncture the battery.
Pry up and remove the battery.
Remove the sixteen 4mm Phillips #00 screws attaching the back cover to the motherboard.
Use the flat end of a spudger to disconnect the front camera flex cable.
Use a pair of tweezers to carefully remove the front facing camera. Be careful to only grip the body of the camera, as the top is the sensor pcb and is only held on with glue (removal will ruin the sensor).
다른 4명이 해당 안내서를 완성하였습니다.
