소개
Are all your photos on the LG V20 coming out blurry? There is probably an issue with the rear-facing camera. This guide will take you through the steps required to remove the camera.
필요한 것
Insert a spudger or your fingernail under the battery at the small recess on the lower edge.
Be careful not to deform or puncture the battery.
Pry up and remove the battery.
Remove the sixteen 4mm Phillips #00 screws attaching the back cover to the motherboard.
Use the flat end of a spudger to disconnect the front camera flex cable.
Use a pair of tweezers to carefully remove the front facing camera. Be careful to only grip the body of the camera, as the top is the sensor pcb and is only held on with glue (removal will ruin the sensor).
Use the flat end of a spudger to disconnect the flex cable of the left rear camera.
The second rear camera will come out with the motherboard since it is connected on the other side.
You can leave the front facing camera in its place as long as you're careful while removing the motherboard assembly. However if you feel uncertain, carefully remove it with a pair of tweezers.
Flip the motherboard assembly and use the flat end of a spudger to carefully disconnect the flex cable of the rear camera.
Use a pair of tweezers to remove the rear camera.
다른 6명이 해당 안내서를 완성하였습니다.
