소개
Use this guide to remove the rear lens cover of your LG V20.
  1. Press the button on the lower right side of the LG V20 to open the clamp that holds the back cover on the back side of the phone. Remove the back cover. Remove the back cover.
    • Press the button on the lower right side of the LG V20 to open the clamp that holds the back cover on the back side of the phone.
    • Remove the back cover.
  2. Before disassembling your phone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured. Use the flat end of a spudger and insert it in the small recess at the lower end of the battery. Use the spudger to lever out the battery and remove it.
    • Before disassembling your phone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Use the flat end of a spudger and insert it in the small recess at the lower end of the battery.
    • Use the spudger to lever out the battery and remove it.
    • You can do this with your fingers but take care not to puncture the battery with your fingernails.
  3. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  4. Use an iOpener to loosen the adhesive beneath the rear lens cover.
  5. Use the tip of an opening pick to gently pry up the rear lens cover. Use the tip of the opening pick and slide around the whole rear lens cover to cut the adhesive beneath. Use the tip of the opening pick and slide around the whole rear lens cover to cut the adhesive beneath.
    • Use the tip of an opening pick to gently pry up the rear lens cover.
    • Use the tip of the opening pick and slide around the whole rear lens cover to cut the adhesive beneath.
  6. Remove the rear lens cover.
    • Remove the rear lens cover.
결론
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where it’s necessary.
다른 한 분이 해당 안내서를 완성하였습니다.
Dominik Schnabelrauch
회원 가입일: 2016년 11월 23일
26,229 평판
안내서 125개 작성하였습니다
iFixit iFixit 회원
Community
100 회원들
안내서 7,949개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 50
전체 시간: 350
