주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG V20 Volume Button Replacement
필요한 것
  1. LG V20 Volume Button Replacement, Battery: 1 단계, 이미지 3개 중 1개 LG V20 Volume Button Replacement, Battery: 1 단계, 이미지 3개 중 2개 LG V20 Volume Button Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Before disassembling your phone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Insert a spudger or your fingernail under the battery at the small recess on the lower edge.
    • Be careful not to deform or puncture the battery.
    • Pry up and remove the battery.
  2. LG V20 Volume Button Replacement, Midframe Assembly: 2 단계, 이미지 1개 중 1개
    • Remove the sixteen 4mm Phillips #00 screws attaching the back cover to the motherboard.
  3. LG V20 Volume Button Replacement: 3 단계, 이미지 2개 중 1개 LG V20 Volume Button Replacement: 3 단계, 이미지 2개 중 2개
    • The top and bottom frame section hold very tight to the mid frame. It is possible to pull them off with your hands. If you're not able to do so, use the following removal procedure:
    • Use the flat end of a spudger and apply pressure to one of the corners of the frame section until you create a small gap.
  4. LG V20 Volume Button Replacement: 4 단계, 이미지 2개 중 1개 LG V20 Volume Button Replacement: 4 단계, 이미지 2개 중 2개
    • Flip the phone and insert an opening pick in the gap you created.
    • Slide the opening pick along the gap until the frame section pops out of its plastic clamps.
  5. LG V20 Volume Button Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the frame section.
    • Repeat this procedure with the frame section on the other end of the phone.
    • Within the top frame section there's a small silver grating that covers the speaker. This may fall out, so be careful not to lose it.
  6. LG V20 Volume Button Replacement: 6 단계, 이미지 2개 중 1개 LG V20 Volume Button Replacement: 6 단계, 이미지 2개 중 2개
    • The loudspeaker is attached to the cover of the motherboard. Use an opening pick to pry it up.
  7. LG V20 Volume Button Replacement: 7 단계, 이미지 2개 중 1개 LG V20 Volume Button Replacement: 7 단계, 이미지 2개 중 2개
    • The cover of the motherboard is held in its place by several plastic clamps.
    • Use an opening pick to pry up the motherboard cover at the right corner at the bottom of your phone until it pops out of the plastic clamp.
  8. LG V20 Volume Button Replacement: 8 단계, 이미지 2개 중 1개 LG V20 Volume Button Replacement: 8 단계, 이미지 2개 중 2개
    • Slide the opening pick along the mid frame and flip it sideways to open the plastic clamps holding the motherboard cover in its place.
  9. LG V20 Volume Button Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the motherboard cover.
  10. LG V20 Volume Button Replacement, Volume Button: 10 단계, 이미지 2개 중 1개 LG V20 Volume Button Replacement, Volume Button: 10 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to slide the volume button out of its bracket and remove it.
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Garrett Janney
회원 가입일: 04/26/17
909 평판
안내서 4개를 작성함
Cal Poly, Team S22-G5, Livingston Spring 2017 Cal Poly, Team S22-G5, Livingston Spring 2017 회원
CPSU-LIVINGSTON-S17S22G5
4 회원들
안내서 36개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 79
전체 시간: 3,641
