주요 콘텐츠로 건너뛰기
LG V30 Plus Display Assembly Replacement
필요한 것
  1. LG V30 Plus Display Assembly Replacement, Rear Glass: 1 단계, 이미지 1/1
    • Use a pair of iOpeners by heating them in a microwave and placing the hot pads on the edges of the phone.
    • Allow to sit for 1-2 minutes to heat up the adhesive.
    • A heat gun may need to be used if you have trouble separating the backing in the next step.
  2. LG V30 Plus Display Assembly Replacement: 2 단계, 이미지 1/2 LG V30 Plus Display Assembly Replacement: 2 단계, 이미지 2/2
    • Insert an Opening Tool into the seam between the rear glass and side of the phone.
    • Pry the glass off just enough to insert an Opening Pick.
    • Slide the Opening Tool around the edges of the device, placing Opening Picks regularly.
  3. LG V30 Plus Display Assembly Replacement: 3 단계, 이미지 1/1
    • Once all edges of the device are lifted free, use a Suction Handle to gently pull the rear glass off the device.
  4. LG V30 Plus Display Assembly Replacement, Motherboard: 4 단계, 이미지 1/2 LG V30 Plus Display Assembly Replacement, Motherboard: 4 단계, 이미지 2/2
    • Remove the ten 4mm screws using the Phillips #00 Screwdriver.
  5. LG V30 Plus Display Assembly Replacement: 5 단계, 이미지 1/3 LG V30 Plus Display Assembly Replacement: 5 단계, 이미지 2/3 LG V30 Plus Display Assembly Replacement: 5 단계, 이미지 3/3
    • Gently push down on the small black tab with a Spudger to release the protective board.
    • Slide an Opening Tool between the phone and the protective board and slide along the edges of the phone to unclip it.
    • Carefully wiggle the board back and forth while gently pulling to unclip the last attachment point.
  6. LG V30 Plus Display Assembly Replacement: 6 단계, 이미지 1/2 LG V30 Plus Display Assembly Replacement: 6 단계, 이미지 2/2
    • Slide an Opening Tool between the lower protective board and the phone to unclip.
    • Slide the tool along the remaining edges of the protective board until it pops off.
  7. LG V30 Plus Display Assembly Replacement: 7 단계, 이미지 1/2 LG V30 Plus Display Assembly Replacement: 7 단계, 이미지 2/2
    • Gently pry each visible ribbon cable away from the motherboard to disconnect them.
  8. LG V30 Plus Display Assembly Replacement: 8 단계, 이미지 1/1
    • Gently remove the motherboard from the phone.
  9. LG V30 Plus Display Assembly Replacement, Battery: 9 단계, 이미지 1/3 LG V30 Plus Display Assembly Replacement, Battery: 9 단계, 이미지 2/3 LG V30 Plus Display Assembly Replacement, Battery: 9 단계, 이미지 3/3
    • Use a Spudger to get between the battery and the phone and pry each edge of the battery away from the board.
    • There may be a strong adhesive under the battery, so work your way around the battery carefully and slowly.
    • Insert Opening Picks if needed to keep the battery elevated.
  10. LG V30 Plus Display Assembly Replacement, Front-Facing Camera: 10 단계, 이미지 1/2 LG V30 Plus Display Assembly Replacement, Front-Facing Camera: 10 단계, 이미지 2/2
    • Use a Spudger to pry away the front-facing camera from the board.
  11. LG V30 Plus Display Assembly Replacement, Display Assembly: 11 단계, 이미지 1/1
    • Pull the ribbon cable attached to the screen away from the board and make sure it is bent upwards and out of the way.
  12. LG V30 Plus Display Assembly Replacement: 12 단계, 이미지 1/1
    • Warm up a pair of iOpeners in the microwave for 1-2 minutes.
    • Place the iOpeners on the edges of the phone and wait a couple of minutes for it to heat up the adhesive.
    • A heat gun may be necessary to heat the adhesive if the screen refuses to separate in the next step.
  13. LG V30 Plus Display Assembly Replacement: 13 단계, 이미지 1/3 LG V30 Plus Display Assembly Replacement: 13 단계, 이미지 2/3 LG V30 Plus Display Assembly Replacement: 13 단계, 이미지 3/3
    • Insert an Opening Tool between the metal sides of the phone and the front glass.
    • Slide the Opening Tool around the display, placing Opening Picks as necessary.
    • Use a Suction Handle or hand to remove the screen from the body of the phone.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Geoffrey Smith
회원 가입일: 04/18/19
395 평판
안내서 3개 작성하였습니다
Cal Poly, Team S1-G3, Maness Spring 2019 Cal Poly, Team S1-G3, Maness Spring 2019 회원
CPSU-MANESS-S19S1G3
4 회원들
안내서 10개 작성하였습니다
댓글 한 개
Do you have a link to give me where I could by an ORIGINAL screen for this phone ?
Thank you !
micheleoliani@gmail.com
Mi Ka El - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 17
전체 시간: 1,136
