주요 콘텐츠로 건너뛰기
LG V30 Plus Front-Facing Camera Replacement
필요한 것
  1. LG V30 Plus Front-Facing Camera Replacement, Rear Glass: 1 단계, 이미지 1/1
    • Use a pair of iOpeners by heating them in a microwave and placing the hot pads on the edges of the phone.
    • Allow to sit for 1-2 minutes to heat up the adhesive.
    • A heat gun may need to be used if you have trouble separating the backing in the next step.
  2. LG V30 Plus Front-Facing Camera Replacement: 2 단계, 이미지 1/2 LG V30 Plus Front-Facing Camera Replacement: 2 단계, 이미지 2/2
    • Insert an Opening Tool into the seam between the rear glass and side of the phone.
    • Pry the glass off just enough to insert an Opening Pick.
    • Slide the Opening Tool around the edges of the device, placing Opening Picks regularly.
  3. LG V30 Plus Front-Facing Camera Replacement: 3 단계, 이미지 1/1
    • Once all edges of the device are lifted free, use a Suction Handle to gently pull the rear glass off the device.
  4. LG V30 Plus Front-Facing Camera Replacement, Motherboard: 4 단계, 이미지 1/2 LG V30 Plus Front-Facing Camera Replacement, Motherboard: 4 단계, 이미지 2/2
    • Remove the ten 4mm screws using the Phillips #00 Screwdriver.
  5. LG V30 Plus Front-Facing Camera Replacement: 5 단계, 이미지 1/3 LG V30 Plus Front-Facing Camera Replacement: 5 단계, 이미지 2/3 LG V30 Plus Front-Facing Camera Replacement: 5 단계, 이미지 3/3
    • Gently push down on the small black tab with a Spudger to release the protective board.
    • Slide an Opening Tool between the phone and the protective board and slide along the edges of the phone to unclip it.
    • Carefully wiggle the board back and forth while gently pulling to unclip the last attachment point.
  6. LG V30 Plus Front-Facing Camera Replacement: 6 단계, 이미지 1/2 LG V30 Plus Front-Facing Camera Replacement: 6 단계, 이미지 2/2
    • Slide an Opening Tool between the lower protective board and the phone to unclip.
    • Slide the tool along the remaining edges of the protective board until it pops off.
  7. LG V30 Plus Front-Facing Camera Replacement: 7 단계, 이미지 1/2 LG V30 Plus Front-Facing Camera Replacement: 7 단계, 이미지 2/2
    • Gently pry each visible ribbon cable away from the motherboard to disconnect them.
  8. LG V30 Plus Front-Facing Camera Replacement: 8 단계, 이미지 1/1
    • Gently remove the motherboard from the phone.
  9. LG V30 Plus Front-Facing Camera Replacement, Battery: 9 단계, 이미지 1/3 LG V30 Plus Front-Facing Camera Replacement, Battery: 9 단계, 이미지 2/3 LG V30 Plus Front-Facing Camera Replacement, Battery: 9 단계, 이미지 3/3
    • Use a Spudger to get between the battery and the phone and pry each edge of the battery away from the board.
    • There may be a strong adhesive under the battery, so work your way around the battery carefully and slowly.
    • Insert Opening Picks if needed to keep the battery elevated.
  10. LG V30 Plus Front-Facing Camera Replacement, Front-Facing Camera: 10 단계, 이미지 1/2 LG V30 Plus Front-Facing Camera Replacement, Front-Facing Camera: 10 단계, 이미지 2/2
    • Use a Spudger to pry away the front-facing camera from the board.
결론
Samuel Jahnke
회원 가입일: 04/22/19
279 평판
안내서 2개 작성하였습니다
Cal Poly, Team S1-G3, Maness Spring 2019 Cal Poly, Team S1-G3, Maness Spring 2019 회원
CPSU-MANESS-S19S1G3
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 258
