주요 콘텐츠로 건너뛰기
LG V30 Plus Rear Glass Replacement
필요한 것
  1. LG V30 Plus Rear Glass Replacement, Rear Glass: 1 단계, 이미지 1/1
    • Use a pair of iOpeners by heating them in a microwave and placing the hot pads on the edges of the phone.
    • Allow to sit for 1-2 minutes to heat up the adhesive.
    • A heat gun may need to be used if you have trouble separating the backing in the next step.
  2. LG V30 Plus Rear Glass Replacement: 2 단계, 이미지 1/2 LG V30 Plus Rear Glass Replacement: 2 단계, 이미지 2/2
    • Insert an Opening Tool into the seam between the rear glass and side of the phone.
    • Pry the glass off just enough to insert an Opening Pick.
    • Slide the Opening Tool around the edges of the device, placing Opening Picks regularly.
  3. LG V30 Plus Rear Glass Replacement: 3 단계, 이미지 1/1
    • Once all edges of the device are lifted free, use a Suction Handle to gently pull the rear glass off the device.
결론
Geoffrey Smith
회원 가입일: 04/18/19
395 평판
안내서 3개 작성하였습니다
Cal Poly, Team S1-G3, Maness Spring 2019 Cal Poly, Team S1-G3, Maness Spring 2019 회원
CPSU-MANESS-S19S1G3
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 7
전체 시간: 1,030
