주요 콘텐츠로 건너뛰기
LG V30 Rear Camera Replacement
필요한 것
동영상 개요
  1. LG V30 Rear Camera Replacement, Rear Camera: 1 단계, 이미지 1/3 LG V30 Rear Camera Replacement, Rear Camera: 1 단계, 이미지 2/3 LG V30 Rear Camera Replacement, Rear Camera: 1 단계, 이미지 3/3
    • Insert a SIM card eject tool into the small hole on the right side of the phone to release the SIM card tray from the phone.
    • Pull the SIM card tray out from the phone.
  2. LG V30 Rear Camera Replacement: 2 단계, 이미지 1/2 LG V30 Rear Camera Replacement: 2 단계, 이미지 2/2
    • Use a heat gun to apply heat to the back cover.
  3. LG V30 Rear Camera Replacement: 3 단계, 이미지 1/3 LG V30 Rear Camera Replacement: 3 단계, 이미지 2/3 LG V30 Rear Camera Replacement: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    구매
    • Use a suction cup to lift up the back cover up.
    • Insert the edge of a plastic card into the space created between the cover and frame.
  4. LG V30 Rear Camera Replacement: 4 단계, 이미지 1/3 LG V30 Rear Camera Replacement: 4 단계, 이미지 2/3 LG V30 Rear Camera Replacement: 4 단계, 이미지 3/3
    • Insert a second card where you have created an opening with the first card and slide it along the bottom edge of the phone.
  5. LG V30 Rear Camera Replacement: 5 단계, 이미지 1/3 LG V30 Rear Camera Replacement: 5 단계, 이미지 2/3 LG V30 Rear Camera Replacement: 5 단계, 이미지 3/3
    • Continue to slide the cards around the remaining three edges to release the adhesive.
  6. LG V30 Rear Camera Replacement: 6 단계, 이미지 1/3 LG V30 Rear Camera Replacement: 6 단계, 이미지 2/3 LG V30 Rear Camera Replacement: 6 단계, 이미지 3/3
    • Remove the back cover.
  7. LG V30 Rear Camera Replacement: 7 단계, 이미지 1/1
    • Remove the ten Phillips #000 screws from the midframe.
  8. LG V30 Rear Camera Replacement: 8 단계, 이미지 1/3 LG V30 Rear Camera Replacement: 8 단계, 이미지 2/3 LG V30 Rear Camera Replacement: 8 단계, 이미지 3/3
    • Using a plastic spudger, pry up the midframe of the phone.
  9. LG V30 Rear Camera Replacement: 9 단계, 이미지 1/2 LG V30 Rear Camera Replacement: 9 단계, 이미지 2/2
    • Remove the midframe.
  10. LG V30 Rear Camera Replacement: 10 단계, 이미지 1/3 LG V30 Rear Camera Replacement: 10 단계, 이미지 2/3 LG V30 Rear Camera Replacement: 10 단계, 이미지 3/3
    • Use the plastic spudger to pry up the four press fit connectors on the top portion of the motherboard.
  11. LG V30 Rear Camera Replacement: 11 단계, 이미지 1/3 LG V30 Rear Camera Replacement: 11 단계, 이미지 2/3 LG V30 Rear Camera Replacement: 11 단계, 이미지 3/3
    • Pry up the speaker panel with a plastic spudger and remove it from the phone.
  12. LG V30 Rear Camera Replacement: 12 단계, 이미지 1/3 LG V30 Rear Camera Replacement: 12 단계, 이미지 2/3 LG V30 Rear Camera Replacement: 12 단계, 이미지 3/3
    • Use a spudger to pry up the two press fit connectors on the bottom portion of the midframe.
  13. LG V30 Rear Camera Replacement: 13 단계, 이미지 1/3 LG V30 Rear Camera Replacement: 13 단계, 이미지 2/3 LG V30 Rear Camera Replacement: 13 단계, 이미지 3/3
    • Use a spudger to pry up the motherboard and lift it out of the phone's frame.
  14. LG V30 Rear Camera Replacement: 14 단계, 이미지 1/3 LG V30 Rear Camera Replacement: 14 단계, 이미지 2/3 LG V30 Rear Camera Replacement: 14 단계, 이미지 3/3
    • Flip over the motherboard.
    • Using a plastic spudger, pry up the press fit connector for the first camera.
  15. LG V30 Rear Camera Replacement: 15 단계, 이미지 1/2 LG V30 Rear Camera Replacement: 15 단계, 이미지 2/2
    • Remove the camera with a pair of ESD safe tweezers.
  16. LG V30 Rear Camera Replacement: 16 단계, 이미지 1/3 LG V30 Rear Camera Replacement: 16 단계, 이미지 2/3 LG V30 Rear Camera Replacement: 16 단계, 이미지 3/3
    • Pry up the second camera with a spudger.
    • The press fit connector has already been disconnected, but the camera module is still lightly adhered to the motherboard.
    • Remove the second camera with a pair of tweezers.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Witrigs
회원 가입일: 11/24/15
69,454 평판
안내서 378개 작성하였습니다
댓글 한 개
Does this make it no longer waterproof?
Rob Hoover - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 9
30일 전: 12
전체 시간: 2,434
