주요 콘텐츠로 건너뛰기
LG VS810 Screen Replacement
필요한 것
    • Remove the back cover
    • Remove the battery , SIM card, and SD card
    • Unscrew the 8 screws using a Phillips (PH#00) screwdriver
    • Using a plastic opening tool , once again pry up on the edges of the plastic back cover.
    • Working on a magnet board is recommended as the screws are small and can be easily misplaced
    • Gently disconect the screen cable using a spudger.
    • Using the spudger, pry the motherboard away from the screen assembly.
    • Use a heat gun or hairdryer to heat up the edges. This will loosen the glue so the screen can be removed.
    • Continue to heat and separate until the screen comes completely apart from the rest of the phone using plastic tools
    • The phone will be extremely hot. Avoid direct contact with metal pieces.
결론
다른 7명이 해당 안내서를 완성하였습니다.
[deleted]
회원 가입일: 10/25/15
398 평판
안내서 1개 작성함
댓글 한 개
Pls help how can I fix lg-k120e screen
drammehoumar - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 11
전체 시간: 4,353
