소개
How to replace the phone's soft keypad.
필요한 것
Press button labeled "Push". In the photo depicted the button is being depressed by the left finger.
Pull back panel toward bottom of phone.
Remove the 4 small screws from the back panel, under the battery, using 00 Phillips-head.
Starting at the top of the phone near the antenna, use a screwdriver or other small tool, maybe even fingernails, to pry the rear panel off.
By systematically prying up the edges of the back panel, moving about a quarter of an inch, and prying again, the panel will begin to lift off.
Don't be afraid to damage anything, the panel requires a bit of force to detach.
다른 한 분이 해당 안내서를 완성하였습니다.
