주요 콘텐츠로 건너뛰기
LG VX4400 Screen Replacement
필요한 것
  1. LG VX4400 Screen Replacement, Screen: 1 단계, 이미지 1/2 LG VX4400 Screen Replacement, Screen: 1 단계, 이미지 2/2
    • Remove the four rubber stoppers around the main screen using the pointed end of the spudger.
  2. LG VX4400 Screen Replacement: 2 단계, 이미지 1/1
    • Use the Phillips #00 screwdriver to remove the four screws that were under the rubber stoppers.
  3. LG VX4400 Screen Replacement: 3 단계, 이미지 1/3 LG VX4400 Screen Replacement: 3 단계, 이미지 2/3 LG VX4400 Screen Replacement: 3 단계, 이미지 3/3
    • Use a plastic opening tool to pry the top end of the phone open.
    • Use a second plastic opening tool to slide down the gap and pry open the case while prying the top panel with the first plastic opening tool.
    • Use the same method on the opposite side of the phone.
  4. LG VX4400 Screen Replacement: 4 단계, 이미지 1/2 LG VX4400 Screen Replacement: 4 단계, 이미지 2/2
    • Remove plastic screen panel to reveal the internal components.
  5. LG VX4400 Screen Replacement: 5 단계, 이미지 1/3 LG VX4400 Screen Replacement: 5 단계, 이미지 2/3 LG VX4400 Screen Replacement: 5 단계, 이미지 3/3
    • Remove the screen board by lifting it away from the phone.
    • Remove the speaker by prying with the spudger.
  6. LG VX4400 Screen Replacement: 6 단계, 이미지 1/3 LG VX4400 Screen Replacement: 6 단계, 이미지 2/3 LG VX4400 Screen Replacement: 6 단계, 이미지 3/3
    • Press out the plastic screen gently.
결론
Nico Chiarito
회원 가입일: 01/21/10
22 평판
안내서 5개 작성하였습니다
Cal Poly, Team 8-47, Regan Winter 2010 Cal Poly, Team 8-47, Regan Winter 2010 회원
CPSU-REGAN-W10S8G47
5 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 2,477
