주요 콘텐츠로 건너뛰기
LG VX4500 Keypad Replacement
필요한 것
  1. LG VX4500 Keypad Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the closed phone so that the back panel is facing you.
    • Press down and forward firmly on the gray tab in the middle of the phone.
  2. LG VX4500 Keypad Replacement: 2 단계, 이미지 1/2 LG VX4500 Keypad Replacement: 2 단계, 이미지 2/2
    • Now just lift up on the battery and remove it from the phone.
  3. LG VX4500 Keypad Replacement, Rear Cover: 3 단계, 이미지 1/1
    • Remove the rubber grommet using a Spudger.
  4. LG VX4500 Keypad Replacement: 4 단계, 이미지 1/1
    • Be sure not to lose the screws. They are small!
    • Remove the five screws using a Phillips #00 Screwdriver.
  5. LG VX4500 Keypad Replacement: 5 단계, 이미지 1/3 LG VX4500 Keypad Replacement: 5 단계, 이미지 2/3 LG VX4500 Keypad Replacement: 5 단계, 이미지 3/3
    • When removing back cover, be careful not to break the speaker wires.
    • Using an Opening Tool, carefully pry off the back cover.
    • Using tweezers, gently pull the speaker wires out.
  6. LG VX4500 Keypad Replacement: 6 단계, 이미지 1/1
    • Separate the two halves.
  7. LG VX4500 Keypad Replacement, Keypad: 7 단계, 이미지 1/3 LG VX4500 Keypad Replacement, Keypad: 7 단계, 이미지 2/3 LG VX4500 Keypad Replacement, Keypad: 7 단계, 이미지 3/3
    • Carefully pry and lift up on the logic board using an iPod Opening Tool.
  8. LG VX4500 Keypad Replacement: 8 단계, 이미지 1/1
    • Carefully flip the logic board up and out of the way.
  9. LG VX4500 Keypad Replacement: 9 단계, 이미지 1/3 LG VX4500 Keypad Replacement: 9 단계, 이미지 2/3 LG VX4500 Keypad Replacement: 9 단계, 이미지 3/3
    • Use an iPod Opening Tool to lift up on the keypad and pull it out.
결론
David Foster
회원 가입일: 04/11/10
1 평판
안내서 8개 작성하였습니다
Cal Poly, Team 25-88, Amido Spring 2010 Cal Poly, Team 25-88, Amido Spring 2010 회원
CPSU-AMIDO-S10S25G88
4 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 1,017
