소개
Replacing the outer display cover.
  1. Turn the closed phone so that the back panel is facing you.
    • Turn the closed phone so that the back panel is facing you.
    • Press down and forward firmly on the gray tab in the middle of the phone.
  2. Now just lift up on the battery and remove it from the phone.
    • Now just lift up on the battery and remove it from the phone.
    • Remove 4 rubber grommets using the Spudger.
    • Remove 4 screws using the Phillips #00 Screwdriver.
    • Carefully pry off outer cover using iPod Opening Tool.
결론
David Foster
회원 가입일: 2010년 04월 11일
1 평판
안내서 8개 작성하였습니다
Cal Poly, Team 25-88, Amido Spring 2010 Cal Poly, Team 25-88, Amido Spring 2010 회원
CPSU-AMIDO-S10S25G88
4 회원들
안내서 18개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 1,358
