주요 콘텐츠로 건너뛰기
LG VX4500 keyboard replacement duplicate
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. LG VX4500 keyboard replacement duplicate, Battery: 1 단계, 이미지 1/1
    • Before removing the battery, ensure that the phone is turned off.
    • To remove the battery from your LG VX4500, turn the phone so that the back panel is showing.
  2. LG VX4500 keyboard replacement duplicate: 2 단계, 이미지 1/1
    • Pull back on the white release tab and lift up the the entire battery.
  3. LG VX4500 keyboard replacement duplicate: 3 단계, 이미지 1/1
    • The back panel should now be fully accessible.
  4. LG VX4500 keyboard replacement duplicate, LG VX4500 Disassembly: 4 단계, 이미지 1/2 LG VX4500 keyboard replacement duplicate, LG VX4500 Disassembly: 4 단계, 이미지 2/2
    • Using a paper clip, remove all 4 rubber screwcaps from the screw ports.
    • With a Phillips head screwdriver, remove all 4 screws from their ports.
    • Also remove the rubber screwcap in the upper part of the back panel along with the screw under it.
    • The fifth screw will be more difficult to get out because the plastic port has much higher sides.
  5. LG VX4500 keyboard replacement duplicate: 5 단계, 이미지 1/3 LG VX4500 keyboard replacement duplicate: 5 단계, 이미지 2/3 LG VX4500 keyboard replacement duplicate: 5 단계, 이미지 3/3
    • Run a plastic opening tool along the seam to seperate the keyboard cover and the back panel
    • Remove the back panel, now the logic board, keyboard and microphone are exposed.
  6. LG VX4500 keyboard replacement duplicate, Logic Board: 6 단계, 이미지 1/2 LG VX4500 keyboard replacement duplicate, Logic Board: 6 단계, 이미지 2/2
    • With your fingers, gently lift up the gold connector until it is completely disconnected.
  7. LG VX4500 keyboard replacement duplicate, Keyboard: 7 단계, 이미지 1/1
    • Move the logic board out of the way to reveal the keyboard underneath.
  8. LG VX4500 keyboard replacement duplicate: 8 단계, 이미지 1/2 LG VX4500 keyboard replacement duplicate: 8 단계, 이미지 2/2
    • Pop the keyboard out using a your finger until the entire keyboard is out.
결론
iDeleted
회원 가입일: 07/07/10
2,101 평판
안내서 39개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 10
전체 시간: 328
