소개
An LG VX4500 phone motherboard may become damaged after being exposed to excessive moisture or severe temperatures and from dropping the phone. If your motherboard becomes damaged, this guide will show you how to successfully replace it. A special skill required to complete this guide is soldering.
필요한 것
Turn the closed phone so that the back panel is facing you.
Press down and forward firmly on the gray tab in the middle of the phone.
Use a soldering iron to desolder the solder joint on the front of the motherboard.
거의 끝나갑니다!
결론
