이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Orient the phone as shown.
Remove the battery cover by pushing upward with your thumb.
Place your fingernail at the top of the battery and pry the battery out towards you.
Remove the 2 plastic plugs located on the side and upper quadrant of the rear body panel by using the push-pin and lifting outwards.
Use a Phillips #00 screwdriver to remove the 5 screws as shown here.
Place an iPod opener tool in the seam above the antenna.
Run the tool around the perimeter of the entire phone.
Locate the screw and copper fixture that hold the antenna in place.
Remove the screw from the device using a Philips #00 screwdriver.
