주요 콘텐츠로 건너뛰기
LG VX5200 Camera Replacement
필요한 것
  1. LG VX5200 Camera Replacement, Battery: 1 단계, 이미지 2개 중 1개 LG VX5200 Camera Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Turn the phone on its back.
  2. LG VX5200 Camera Replacement: 2 단계, 이미지 2개 중 1개 LG VX5200 Camera Replacement: 2 단계, 이미지 2개 중 2개
    • Orient the phone as shown.
    • Remove the battery cover by pushing upward with your thumb.
  3. LG VX5200 Camera Replacement: 3 단계, 이미지 2개 중 1개 LG VX5200 Camera Replacement: 3 단계, 이미지 2개 중 2개
    • Place your fingernail at the top of the battery and pry the battery out towards you.
  4. LG VX5200 Camera Replacement, Face Plate: 4 단계, 이미지 3개 중 1개 LG VX5200 Camera Replacement, Face Plate: 4 단계, 이미지 3개 중 2개 LG VX5200 Camera Replacement, Face Plate: 4 단계, 이미지 3개 중 3개
    • Flip the phone open.
    • Remove the four rubber plugs, located at the corners of the LCD screen, with a push-pin.
    • Use a Phillips #00 screwdriver to remove the four screws located underneath the rubber plugs.
  5. LG VX5200 Camera Replacement: 5 단계, 이미지 3개 중 1개 LG VX5200 Camera Replacement: 5 단계, 이미지 3개 중 2개 LG VX5200 Camera Replacement: 5 단계, 이미지 3개 중 3개
    • Insert the opening tool in the seam of the top portion of the flip phone.
    • Gently pry the seam open.
    • Move the opening tool around the perimeter of the seam and gently take the front LCD face plate out.
  6. LG VX5200 Camera Replacement: 6 단계, 이미지 3개 중 1개 LG VX5200 Camera Replacement: 6 단계, 이미지 3개 중 2개 LG VX5200 Camera Replacement: 6 단계, 이미지 3개 중 3개
    • Close the flip phone.
    • Hold the base of the phone and gently remove the faceplate.
    • Place the phone and the faceplate on a clean, flat surface.
  7. LG VX5200 Camera Replacement, Camera: 7 단계, 이미지 3개 중 1개 LG VX5200 Camera Replacement, Camera: 7 단계, 이미지 3개 중 2개 LG VX5200 Camera Replacement, Camera: 7 단계, 이미지 3개 중 3개
    • Locate the phone camera.
    • Locate the white rubber stopper to left of the camera.
    • Remove white rubber stopper by grabbing an edge with your fingers and gently pulling it off.
  8. LG VX5200 Camera Replacement: 8 단계, 이미지 2개 중 1개 LG VX5200 Camera Replacement: 8 단계, 이미지 2개 중 2개
    • Lift the copper ribbon cable up from the bottom right hand corner.
  9. LG VX5200 Camera Replacement: 9 단계, 이미지 2개 중 1개 LG VX5200 Camera Replacement: 9 단계, 이미지 2개 중 2개
    • While holding the copper connection out of the way, use your fingernail to pry the camera out of its socket.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Douglas Blaalid
회원 가입일: 01/13/10
282 평판
안내서 8개를 작성함
Cal Poly, Team 4-13, Forte Winter 2010 Cal Poly, Team 4-13, Forte Winter 2010 회원
CPSU-FORTE-W10S4G13
5 회원들
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 6
전체 시간: 2,330
