이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Orient the phone as shown.
Remove the battery cover by pushing upward with your thumb.
Place your fingernail at the top of the battery and pry the battery out towards you.
Flip the phone open.
Remove the four rubber plugs, located at the corners of the LCD screen, with a push-pin.
Use a Phillips #00 screwdriver to remove the four screws located underneath the rubber plugs.
Insert the opening tool in the seam of the top portion of the flip phone.
Gently pry the seam open.
Move the opening tool around the perimeter of the seam and gently take the front LCD face plate out.
Close the flip phone.
Hold the base of the phone and gently remove the faceplate.
Place the phone and the faceplate on a clean, flat surface.
다른 한 분이 해당 안내서를 완성하였습니다.
