주요 콘텐츠로 건너뛰기
LG VX5200 Keypad Replacement
필요한 것
  1. LG VX5200 Keypad Replacement, Battery: 1 단계, 이미지 2개 중 1개 LG VX5200 Keypad Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Turn the phone on its back.
  2. LG VX5200 Keypad Replacement: 2 단계, 이미지 2개 중 1개 LG VX5200 Keypad Replacement: 2 단계, 이미지 2개 중 2개
    • Orient the phone as shown.
    • Remove the battery cover by pushing upward with your thumb.
  3. LG VX5200 Keypad Replacement: 3 단계, 이미지 2개 중 1개 LG VX5200 Keypad Replacement: 3 단계, 이미지 2개 중 2개
    • Place your fingernail at the top of the battery and pry the battery out towards you.
  4. LG VX5200 Keypad Replacement, LG VX5200 Rear Body Panel Disassembly: 4 단계, 이미지 1개 중 1개
    • Orient the phone as shown with the battery already removed.
  5. LG VX5200 Keypad Replacement: 5 단계, 이미지 3개 중 1개 LG VX5200 Keypad Replacement: 5 단계, 이미지 3개 중 2개 LG VX5200 Keypad Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the 2 plastic plugs located on the side and upper quadrant of the rear body panel by using the push-pin and lifting outwards.
    • Use a Phillips #00 screwdriver to remove the 5 screws as shown here.
  6. LG VX5200 Keypad Replacement: 6 단계, 이미지 3개 중 1개 LG VX5200 Keypad Replacement: 6 단계, 이미지 3개 중 2개 LG VX5200 Keypad Replacement: 6 단계, 이미지 3개 중 3개
    • Place an iPod opener tool in the seam above the antenna.
    • Run the tool around the perimeter of the entire phone.
  7. LG VX5200 Keypad Replacement: 7 단계, 이미지 1개 중 1개
    • Check to see that your device looks like the attached photo.
  8. LG VX5200 Keypad Replacement, main board: 8 단계, 이미지 3개 중 1개 LG VX5200 Keypad Replacement, main board: 8 단계, 이미지 3개 중 2개 LG VX5200 Keypad Replacement, main board: 8 단계, 이미지 3개 중 3개
    • Locate the tabs that hold the logic board in place.
    • Pull the outer frame of the phone outwards to release the board from the tabs.
  9. LG VX5200 Keypad Replacement: 9 단계, 이미지 3개 중 1개 LG VX5200 Keypad Replacement: 9 단계, 이미지 3개 중 2개 LG VX5200 Keypad Replacement: 9 단계, 이미지 3개 중 3개
    • Locate the copper connection (orange-colored) on the back of the board.
    • Pry the connector free from the board with your fingernail.
  10. LG VX5200 Keypad Replacement: 10 단계, 이미지 1개 중 1개
    • Check to see that your device looks like the image shown.
    • Note: The image is shown with the LCD screen removed. This is not necessary for logic board removal.
  11. LG VX5200 Keypad Replacement, Keypad: 11 단계, 이미지 3개 중 1개 LG VX5200 Keypad Replacement, Keypad: 11 단계, 이미지 3개 중 2개 LG VX5200 Keypad Replacement, Keypad: 11 단계, 이미지 3개 중 3개
    • Use your finger to lift up the keypad.
  12. LG VX5200 Keypad Replacement: 12 단계, 이미지 1개 중 1개
    • Do not let the buttons fall out of the side casing of the phone!
    • Note: The image is shown with the LCD screen removed. This is not necessary for keypad repair.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Douglas Blaalid
회원 가입일: 01/13/10
282 평판
안내서 8개를 작성함
Cal Poly, Team 4-13, Forte Winter 2010 Cal Poly, Team 4-13, Forte Winter 2010 회원
CPSU-FORTE-W10S4G13
5 회원들
안내서 15개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 1,903
