소개
A guide to removing the LCD screen.
  1. Turn the phone on its back.
    • Turn the phone on its back.
    댓글 쓰기
  2. Orient the phone as shown.
    • Orient the phone as shown.
    • Remove the battery cover by pushing upward with your thumb.
    댓글 쓰기
    • Place your fingernail at the top of the battery and pry the battery out towards you.
    댓글 쓰기
    • Flip the phone open.
    • Remove the four rubber plugs, located at the corners of the LCD screen, with a push-pin.
    • Use a Phillips #00 screwdriver to remove the four screws located underneath the rubber plugs.
    댓글 쓰기
  3. Fixmas/픽스마스 분위기를 띄우세요
    FIXMAS12 코드로 $50 이상 구매시 $12 할인을 받으십시오
    • Insert the plastic opening tool in the seam of the top portion of the flip phone.
    • Gently pry the seam open.
    • Move the opening tool around the perimeter of the seam and gently take the front LCD face plate out.
    댓글 쓰기
    • Close the flip phone.
    • Hold the base of the phone and gently remove the faceplate.
    • Place the phone and the faceplate on a clean, flat surface.
    댓글 쓰기
    • Try not to move the thin component wires as they will bend and break very easily.
    • The speaker is the dark gray, larger circular-shaped piece to the right of the battery. Attached to it are the four thin wires.
    • The vibrator wires are thinner and even more fragile.
    댓글 쓰기
    • Remove the white stopper from the camera light located above the gold connector.
    • Lift the gold connector up with your finger to detach it.
    댓글 쓰기
    • Gently lift out the speaker with your fingertip.
    댓글 쓰기
    • Gently lift out the square LCD assembly being careful with the attached vibrator wires.
    • Gently remove the vibrator with tweezers.
    • The LCD screen, speaker and vibrator will separate from the phone as a single unit.
    댓글 쓰기
    • Place phone body and LCD screen on a clean, lint-free surface.
    댓글 쓰기
결론
다른 3명이 해당 안내서를 완성하였습니다.
Douglas Blaalid
회원 가입일: 2010년 01월 13일
282 평판
안내서 8개 작성하였습니다
Cal Poly, Team 4-13, Forte Winter 2010 Cal Poly, Team 4-13, Forte Winter 2010 회원
CPSU-FORTE-W10S4G13
5 회원들
안내서 15개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 3,600
