주요 콘텐츠로 건너뛰기
LG VX5200 Screen Replacement
필요한 것
  1. LG VX5200 Screen Replacement, Screen: 1 단계, 이미지 1/3 LG VX5200 Screen Replacement, Screen: 1 단계, 이미지 2/3 LG VX5200 Screen Replacement, Screen: 1 단계, 이미지 3/3
    • Pry the grey pieces of plastic off the corners of the screen with a spudger.
  2. LG VX5200 Screen Replacement: 2 단계, 이미지 1/2 LG VX5200 Screen Replacement: 2 단계, 이미지 2/2
    • Unscrew each of the four screws with a Phillips #00 Screwdriver.
    • These screws are the same size as the ones from the back casing, but are not the same size as the screw from the antenna.
  3. LG VX5200 Screen Replacement: 3 단계, 이미지 1/2 LG VX5200 Screen Replacement: 3 단계, 이미지 2/2
    • Close the phone after removing the screws.
    • Slide a spudger into the cracks in the top half of the phone's casing.
    • Wedge and lever the spudger to remove the casing.
    • Apply constant pressure to avoid cracking the plastic casing. This step can take a few minutes.
  4. LG VX5200 Screen Replacement: 4 단계, 이미지 1/3 LG VX5200 Screen Replacement: 4 단계, 이미지 2/3 LG VX5200 Screen Replacement: 4 단계, 이미지 3/3
    • Remove the chipboard from the screen by sliding a plastic spudger under the screen and lifting.
    • Use a plastic spudger to avoid short-circuiting the phone's electronics.
    • Gently lift the speaker out of the plastic casing using a plastic spudger.
    • Remove the small battery adjacent to the speaker with a plastic spudger.
  5. LG VX5200 Screen Replacement: 5 단계, 이미지 1/3 LG VX5200 Screen Replacement: 5 단계, 이미지 2/3 LG VX5200 Screen Replacement: 5 단계, 이미지 3/3
    • Slide and lever a plastic spudger between the screen and it's housing.
    • Avoid tearing the wires connecting the screen, the small battery and the speaker.
    • Remove the chip connecting the screen to the camera using your fingers.
결론
jmarcum
회원 가입일: 10/28/09
16 평판
안내서 1개 작성함
Cal Poly, Team 9-18, Regan Fall 2009 Cal Poly, Team 9-18, Regan Fall 2009 회원
CPSU-REGAN-F09S9G18
5 회원들
안내서 2개 작성하였습니다
댓글 한 개
The “battery” beside the speaker isn’t the battery, it’s the phone vibrator. Still a good guide, however
Kaleb White - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 3,392
