주요 콘텐츠로 건너뛰기
LG VX5200 motherboard replacement
필요한 것
  1. LG VX5200 motherboard replacement, Battery: 1 단계, 이미지 2개 중 1개 LG VX5200 motherboard replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Turn the phone on its back.
  2. LG VX5200 motherboard replacement: 2 단계, 이미지 2개 중 1개 LG VX5200 motherboard replacement: 2 단계, 이미지 2개 중 2개
    • Orient the phone as shown.
    • Remove the battery cover by pushing upward with your thumb.
  3. LG VX5200 motherboard replacement: 3 단계, 이미지 2개 중 1개 LG VX5200 motherboard replacement: 3 단계, 이미지 2개 중 2개
    • Place your fingernail at the top of the battery and pry the battery out towards you.
  4. LG VX5200 motherboard replacement, LG VX5200 Rear Body Panel Disassembly: 4 단계, 이미지 1개 중 1개
    • Orient the phone as shown with the battery already removed.
  5. LG VX5200 motherboard replacement: 5 단계, 이미지 3개 중 1개 LG VX5200 motherboard replacement: 5 단계, 이미지 3개 중 2개 LG VX5200 motherboard replacement: 5 단계, 이미지 3개 중 3개
    • Remove the 2 plastic plugs located on the side and upper quadrant of the rear body panel by using the push-pin and lifting outwards.
    • Use a Phillips #00 screwdriver to remove the 5 screws as shown here.
  6. LG VX5200 motherboard replacement: 6 단계, 이미지 3개 중 1개 LG VX5200 motherboard replacement: 6 단계, 이미지 3개 중 2개 LG VX5200 motherboard replacement: 6 단계, 이미지 3개 중 3개
    • Place an iPod opener tool in the seam above the antenna.
    • Run the tool around the perimeter of the entire phone.
  7. LG VX5200 motherboard replacement: 7 단계, 이미지 1개 중 1개
    • Check to see that your device looks like the attached photo.
  8. LG VX5200 motherboard replacement, main board: 8 단계, 이미지 3개 중 1개 LG VX5200 motherboard replacement, main board: 8 단계, 이미지 3개 중 2개 LG VX5200 motherboard replacement, main board: 8 단계, 이미지 3개 중 3개
    • Locate the tabs that hold the logic board in place.
    • Pull the outer frame of the phone outwards to release the board from the tabs.
  9. LG VX5200 motherboard replacement: 9 단계, 이미지 3개 중 1개 LG VX5200 motherboard replacement: 9 단계, 이미지 3개 중 2개 LG VX5200 motherboard replacement: 9 단계, 이미지 3개 중 3개
    • Locate the copper connection (orange-colored) on the back of the board.
    • Pry the connector free from the board with your fingernail.
  10. LG VX5200 motherboard replacement: 10 단계, 이미지 1개 중 1개
    • Check to see that your device looks like the image shown.
    • Note: The image is shown with the LCD screen removed. This is not necessary for logic board removal.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Douglas Blaalid
회원 가입일: 01/13/10
282 평판
안내서 8개를 작성함
Cal Poly, Team 4-13, Forte Winter 2010 Cal Poly, Team 4-13, Forte Winter 2010 회원
CPSU-FORTE-W10S4G13
5 회원들
안내서 15개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 2,740
