주요 콘텐츠로 건너뛰기
LG VX5300 Keypad Replacement
필요한 것
  1. LG VX5300 Keypad Replacement, Disassembling Back Cover: 1 단계, 이미지 1/3 LG VX5300 Keypad Replacement, Disassembling Back Cover: 1 단계, 이미지 2/3 LG VX5300 Keypad Replacement, Disassembling Back Cover: 1 단계, 이미지 3/3
    • Carefully slide battery cover off in a downward direction.
    • Using the plastic opening tool, remove the battery. Light force may be necessary.
  2. LG VX5300 Keypad Replacement: 2 단계, 이미지 1/1
    • Using a Phillips #0 screwdriver, remove the five screws from the back cover and carefully set them aside.
  3. LG VX5300 Keypad Replacement: 3 단계, 이미지 1/1
    • Using the plastic opening tool, carefully lift the back cover off.
  4. LG VX5300 Keypad Replacement, Keypad: 4 단계, 이미지 1/2 LG VX5300 Keypad Replacement, Keypad: 4 단계, 이미지 2/2
    • Before touching anything inside the phone: it is crucial that you are very cautious when working around the wiring and sensor bars.
    • Look to the following photo for the location of the two sensor bars.
    • Without disconnecting the orange wire, carefully flip the computer chip over and lay flat on the table, exposing the keypad.
  5. LG VX5300 Keypad Replacement: 5 단계, 이미지 1/2 LG VX5300 Keypad Replacement: 5 단계, 이미지 2/2
    • Carefully remove the keypad and replace with the new keypad.
    • If sensor bars behind the volume and camera buttons fall out, gently put them back in place behind the buttons.
  6. LG VX5300 Keypad Replacement: 6 단계, 이미지 1/1
    • Carefully set the computer chip back in place.
  7. LG VX5300 Keypad Replacement: 7 단계, 이미지 1/2 LG VX5300 Keypad Replacement: 7 단계, 이미지 2/2
    • Place the back cover back on and secure it with the screws.
  8. LG VX5300 Keypad Replacement: 8 단계, 이미지 1/2 LG VX5300 Keypad Replacement: 8 단계, 이미지 2/2
    • Insert the battery.
    • Slide the back cover on the phone.
결승점
Ashley
회원 가입일: 02/12/13
13 평판
안내서 3개 작성하였습니다
Ohio State, Team 1-1, Buehl Spring 2013 Ohio State, Team 1-1, Buehl Spring 2013 회원
OSU-BUEHL-S13S1G1
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 13
전체 시간: 564
