1. Remove the rubber stoppers from the four corners of the front screen.
    • Remove the rubber stoppers from the four corners of the front screen.
  2. Using the Phillips screwdriver, carefully remove all four screws.
    • Using the Phillips screwdriver, carefully remove all four screws.
  3. To pry open the face plate, place the iFixit Opener tool in the crease of the phone. To pry open the face plate, place the iFixit Opener tool in the crease of the phone.
    • To pry open the face plate, place the iFixit Opener tool in the crease of the phone.
  4. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  5. Carefully lift off the black frame around the LCD screen and set it aside. Carefully lift off the black frame around the LCD screen and set it aside.
    • Carefully lift off the black frame around the LCD screen and set it aside.
  6. Lift the speaker out by using tweezers.
    • Lift the speaker out by using tweezers.
    • Next, lift the battery out using the tweezers.
  7. Using tweezers, carefully disconnect the orange ribbon from the computer chip.
    • Using tweezers, carefully disconnect the orange ribbon from the computer chip.
  8. Remove the LCD screen and replace with a new one.
    • Remove the LCD screen and replace with a new one.
    • Finally, replace the battery and the speaker.
결론
Ashley
회원 가입일: 2013년 02월 12일
9 평판
안내서 3개 작성하였습니다
Ohio State, Team 1-1, Buehl Spring 2013 Ohio State, Team 1-1, Buehl Spring 2013 회원
OSU-BUEHL-S13S1G1
3 회원들
안내서 4개 작성하였습니다
Thanks for the instructions. By chance, do you know how to replace the motherboard? Where is the mother board
Sula Tremaine - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 2
전체 시간: 392
