주요 콘텐츠로 건너뛰기
LG VX5300 outer LCD screen replacement
필요한 것
  1. LG VX5300 outer LCD screen replacement, Front LCD Screen: 1 단계, 이미지 1/1
    • Remove the rubber stoppers from the four corners of the front screen.
  2. LG VX5300 outer LCD screen replacement: 2 단계, 이미지 1/1
    • Using the Phillips screwdriver, carefully remove all four screws.
  3. LG VX5300 outer LCD screen replacement: 3 단계, 이미지 1/2 LG VX5300 outer LCD screen replacement: 3 단계, 이미지 2/2
    • To pry open the face plate, place the iFixit Opener tool in the crease of the phone.
  4. LG VX5300 outer LCD screen replacement, LCD Screen: 4 단계, 이미지 1/2 LG VX5300 outer LCD screen replacement, LCD Screen: 4 단계, 이미지 2/2
    • Carefully lift off the black frame around the LCD screen and set it aside.
  5. LG VX5300 outer LCD screen replacement: 5 단계, 이미지 1/1
    • Lift the speaker out by using tweezers.
    • Next, lift the battery out using the tweezers.
  6. LG VX5300 outer LCD screen replacement: 6 단계, 이미지 1/1
    • Using tweezers, carefully disconnect the orange ribbon from the computer chip.
  7. LG VX5300 outer LCD screen replacement: 7 단계, 이미지 1/1
    • Remove the LCD screen and replace with a new one.
    • Finally, replace the battery and the speaker.
결론
Ashley
회원 가입일: 02/12/13
13 평판
안내서 3개 작성하였습니다
Ohio State, Team 1-1, Buehl Spring 2013 Ohio State, Team 1-1, Buehl Spring 2013 회원
OSU-BUEHL-S13S1G1
3 회원들
안내서 4개 작성하였습니다
댓글 한 개
Thanks for the instructions. By chance, do you know how to replace the motherboard? Where is the mother board
Sula Tremaine - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 487
