주요 콘텐츠로 건너뛰기
LG VX5400 Keypad Replacement
필요한 것
  1. LG VX5400 Keypad Replacement, Battery: 1 단계, 이미지 1/1
    • Turn off the cell phone and turn it over on its back side
  2. LG VX5400 Keypad Replacement: 2 단계, 이미지 1/1
    • Hold the phone case in your palm and slide the back cover towards yourself using your thumb
  3. LG VX5400 Keypad Replacement: 3 단계, 이미지 1/3 LG VX5400 Keypad Replacement: 3 단계, 이미지 2/3 LG VX5400 Keypad Replacement: 3 단계, 이미지 3/3
    • Slide a tool or finger into the notch at the top of the battery to carefully remove it.
  4. LG VX5400 Keypad Replacement, Keypad: 4 단계, 이미지 1/1
    • Remove the rubber stopper from the back top of the phone with the pointed end of a spudger.
  5. LG VX5400 Keypad Replacement: 5 단계, 이미지 1/1
    • Use the Phillip screw driver to remove the hidden screw, which is marked by the red square
  6. LG VX5400 Keypad Replacement: 6 단계, 이미지 1/1
    • Gently split open the front and back of the bottom casing of the phone with fingers.
  7. LG VX5400 Keypad Replacement: 7 단계, 이미지 1/1
    • Carefully pull the key pad from the phone through the opening.
  8. LG VX5400 Keypad Replacement: 8 단계, 이미지 1/1
    • See here for parts that have been removed.
결론
Vanessa Panchal
회원 가입일: 04/22/10
1 평판
안내서 1개 작성함
Cal Poly, Team 26-26, Regan Spring 2010 Cal Poly, Team 26-26, Regan Spring 2010 회원
CPSU-REGAN-S10S26G26
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 2,320
