주요 콘텐츠로 건너뛰기
LG VX5400 Phone Casing Replacement
필요한 것
  1. LG VX5400 Phone Casing Replacement, Battery: 1 단계, 이미지 1/1
    • Turn off the cell phone and turn it over on its back side
  2. LG VX5400 Phone Casing Replacement: 2 단계, 이미지 1/1
    • Hold the phone case in your palm and slide the back cover towards yourself using your thumb
  3. LG VX5400 Phone Casing Replacement: 3 단계, 이미지 1/3 LG VX5400 Phone Casing Replacement: 3 단계, 이미지 2/3 LG VX5400 Phone Casing Replacement: 3 단계, 이미지 3/3
    • Slide a tool or finger into the notch at the top of the battery to carefully remove it.
  4. LG VX5400 Phone Casing Replacement, Outer Casing: 4 단계, 이미지 1/1
    • Take the Philips screwdriver and unscrew the four visible screws on the backside of the phone indicated by the four red circles.
  5. LG VX5400 Phone Casing Replacement: 5 단계, 이미지 1/1
    • Then, take the pointed end of a spudger and pry out the rubber stopper to reveal the last screw at the top indicated with the blue circle.
  6. LG VX5400 Phone Casing Replacement, Phone Casing: 6 단계, 이미지 1/3 LG VX5400 Phone Casing Replacement, Phone Casing: 6 단계, 이미지 2/3 LG VX5400 Phone Casing Replacement, Phone Casing: 6 단계, 이미지 3/3
    • Pry open the phone and remove the keypad and logic board.
  7. LG VX5400 Phone Casing Replacement: 7 단계, 이미지 1/2 LG VX5400 Phone Casing Replacement: 7 단계, 이미지 2/2
    • Lay out and organize the parts of the phone. You can now put the inner parts of the phone into the new case.
결론
Tyler
회원 가입일: 04/15/10
20 평판
안내서 1개 작성함
Cal Poly, Team 26-26, Regan Spring 2010 Cal Poly, Team 26-26, Regan Spring 2010 회원
CPSU-REGAN-S10S26G26
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 2,307
