이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the battery cover by placing your thumb on the small ridge near the top of the phone back and push downward, exposing the battery.
Remove the battery using your finger to pry it out of the battery housing.
Remove the (2) rubber screw covers located near the hinge of the phone using tweezers or a thumb tack.
Unscrew the (4) 3.6mm screws using a #00 Phillip's head screw driver.
Carefully pry off the phone's backing using a plastic opening tool.
Slip the tool into the crack between the keypad (front panel) and the back panel.
Slide the tool along the sides of the phone to detach the tabs holding the backing on.
Locate the audio port; this is what it should look like.
The audio port is mounted and connected at 6 points. Check the integrity of these connections.
다른 2명이 해당 안내서를 완성하였습니다.
