주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
This guide gives step-by-step instructions on how to remove the mother board in the LG VX5500 cell phone. To complete the task you will need a #00 Phillip's head screwdriver, tweezers, and a plastic opening tool.
  1. Remove the battery cover by placing your thumb on the small ridge near the top of the phone back and push downward, exposing the battery. Our device did not come with a battery cover so it is not shown here. Remove the battery using your finger to pry it out of the battery housing.
    • Remove the battery cover by placing your thumb on the small ridge near the top of the phone back and push downward, exposing the battery.
    • Our device did not come with a battery cover so it is not shown here.
    • Remove the battery using your finger to pry it out of the battery housing.
  2. Remove the (2) rubber screw covers located near the hinge of the phone using tweezers or a thumb tack. Unscrew the (4) 3.6mm screws using a #00 Phillip's head screw driver.
    • Remove the (2) rubber screw covers located near the hinge of the phone using tweezers or a thumb tack.
    • Unscrew the (4) 3.6mm screws using a #00 Phillip's head screw driver.
  3. Carefully pry off the phone's backing using a plastic opening tool. Slip the tool into the crack between the keypad (front panel) and the back panel. Slide the tool along the sides of the phone to detach the tabs holding the backing on.
    • Carefully pry off the phone's backing using a plastic opening tool.
    • Slip the tool into the crack between the keypad (front panel) and the back panel.
    • Slide the tool along the sides of the phone to detach the tabs holding the backing on.
  4. Peel back the sticker with tweezers and hold it back with your finger. Use the tweezers to lift the display adapter off the logic board.
    • Peel back the sticker with tweezers and hold it back with your finger.
    • Use the tweezers to lift the display adapter off the logic board.
  5. Lift the mother board out of the phone casing. The keyboard can be easily removed once the mother board is out of the phone.
    • Lift the mother board out of the phone casing.
    • The keyboard can be easily removed once the mother board is out of the phone.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Henry
회원 가입일: 2012년 04월 12일
181 평판
안내서 3개 작성하였습니다
Cal Poly, Team 7-33, Maness Spring 2012 Cal Poly, Team 7-33, Maness Spring 2012 회원
CPSU-MANESS-S12S7G33
4 회원들
안내서 10개 작성하였습니다
You guys are great!
Kurt Beske - 답글
So what do you do with the mother board then?
Erik Sodders - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 7
전체 시간: 1,876
