이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
The following guide will show the complete tear down of the phone in order to replace the internal phone casing.
필요한 것
Remove the battery cover by placing your thumb on the small ridge near the top of the phone back and push downward, exposing the battery.
Remove the battery using your finger to pry it out of the battery housing.
Remove the (2) rubber screw covers located near the hinge of the phone using tweezers or a thumb tack.
Unscrew the (4) 3.6mm screws using a #00 Phillip's head screw driver.
Carefully pry off the black plastic screen cover using the iSesamo tool or another thin, flat tool.
다른 3명이 해당 안내서를 완성하였습니다.
