이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the battery cover by placing your thumb on the small ridge near the top of the phone back and push downward, exposing the battery.
Remove the battery using your finger to pry it out of the battery housing.
Remove the (2) rubber screw covers located near the hinge of the phone using tweezers or a thumb tack.
Unscrew the (4) 3.6mm screws using a #00 Phillip's head screw driver.
Carefully pry off the phone's backing using a plastic opening tool.
Slip the tool into the crack between the keypad (front panel) and the back panel.
Slide the tool along the sides of the phone to detach the tabs holding the backing on.
Peel back the sticker with tweezers and hold it back with your finger.
Use the tweezers to lift the display adapter off the logic board.
Lift the mother board out of the phone casing.
The keyboard can be easily removed once the mother board is out of the phone.
Carefully pry off the black plastic screen cover using the iSesamo tool or another thin, flat tool.
Unscrew the (4) 3.6mm screws near each corner of the phone's display panel by using a #00 Phillips head screwdriver.
Pry off the front panel of the phone using a Plastic Opening Tool.
Push the tool into the crack along the side of the phone.
Slide the tool along the crack to detach the tabs holding the backing on the phone.
Remove the earpiece and gyroscope by lifting them out of the phone casing using tweezers.
The phone is now fully disassembled.
Replace the parts indicated with your new phone casing.
다른 3명이 해당 안내서를 완성하였습니다.
