주요 콘텐츠로 건너뛰기
LG VX5500 Screen Replacement
필요한 것
  1. LG VX5500 Screen Replacement, Battery: 1 단계, 이미지 1/3 LG VX5500 Screen Replacement, Battery: 1 단계, 이미지 2/3 LG VX5500 Screen Replacement, Battery: 1 단계, 이미지 3/3
    • Remove the battery cover by placing your thumb on the small ridge near the top of the phone back and push downward, exposing the battery.
    • Our device did not come with a battery cover so it is not shown here.
    • Remove the battery using your finger to pry it out of the battery housing.
  2. LG VX5500 Screen Replacement, Screen: 2 단계, 이미지 1/2 LG VX5500 Screen Replacement, Screen: 2 단계, 이미지 2/2
    • Carefully pry off the black plastic screen cover using the iSesamo tool or another thin, flat tool.
    • The screen cover is adhered to the phone and may take some effort to pry off. If it is too difficult to remove, heat the screen with a hair dryer on low for 30 seconds to soften the adhesive.
  3. LG VX5500 Screen Replacement: 3 단계, 이미지 1/2 LG VX5500 Screen Replacement: 3 단계, 이미지 2/2
    • Unscrew the (4) 3.6mm screws near each corner of the phone's display panel by using a #00 Phillips head screwdriver.
    • The bottom two screws may have small rubber covers that you can remove using tweezers.
  4. LG VX5500 Screen Replacement: 4 단계, 이미지 1/3 LG VX5500 Screen Replacement: 4 단계, 이미지 2/3 LG VX5500 Screen Replacement: 4 단계, 이미지 3/3
    • Pry off the front panel of the phone using a Plastic Opening Tool.
    • Push the tool into the crack along the side of the phone.
    • Slide the tool along the crack to detach the tabs holding the backing on the phone.
  5. LG VX5500 Screen Replacement: 5 단계, 이미지 1/2 LG VX5500 Screen Replacement: 5 단계, 이미지 2/2
    • Use the tweezers to lift the display adapter off the screen component.
  6. LG VX5500 Screen Replacement: 6 단계, 이미지 1/2 LG VX5500 Screen Replacement: 6 단계, 이미지 2/2
    • Using tweezers remove the speaker from its casing.
    • The speaker is adhered to the phone casing so it will take a small amount of force to remove it.
  7. LG VX5500 Screen Replacement: 7 단계, 이미지 1/2 LG VX5500 Screen Replacement: 7 단계, 이미지 2/2
    • Remove the earpiece by lifting it out of the phone casing using tweezers.
    • The earpiece is adhered to the phone casing so it will take a small amount of force to remove it.
  8. LG VX5500 Screen Replacement: 8 단계, 이미지 1/2 LG VX5500 Screen Replacement: 8 단계, 이미지 2/2
    • Remove the vibration motor by lifting it out of the phone casing using tweezers.
    • The motor is adhered to the phone casing so it will take a small amount of force to remove it.
  9. LG VX5500 Screen Replacement: 9 단계, 이미지 1/1
    • Lift the screen components out of the phone.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Henry
회원 가입일: 04/12/12
181 평판
안내서 3개 작성하였습니다
Cal Poly, Team 7-33, Maness Spring 2012 Cal Poly, Team 7-33, Maness Spring 2012 회원
CPSU-MANESS-S12S7G33
4 회원들
안내서 10개 작성하였습니다
댓글 2개
I have it apart know need to learn to solder!
Andy Fowler - 답글
where can i purchase a replacement screen?
kalea dean - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 13
전체 시간: 3,752
