이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the battery cover by placing your thumb on the small ridge near the top of the phone back and push downward, exposing the battery.
Remove the battery using your finger to pry it out of the battery housing.
Carefully pry off the black plastic screen cover using the iSesamo tool or another thin, flat tool.
Unscrew the (4) 3.6mm screws near each corner of the phone's display panel by using a #00 Phillips head screwdriver.
Pry off the front panel of the phone using a Plastic Opening Tool.
Push the tool into the crack along the side of the phone.
Slide the tool along the crack to detach the tabs holding the backing on the phone.
Remove the earpiece by lifting it out of the phone casing using tweezers.
Remove the vibration motor by lifting it out of the phone casing using tweezers.
The motor is adhered to the phone casing so it will take a small amount of force to remove it.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 2개
I have it apart know need to learn to solder!
where can i purchase a replacement screen?
kalea dean - 답글
