소개
In order to install the keypad, the bottom portion of phone will have to be disassembled, but the motherboard will not be required to be completely removed.
필요한 것
Hold your phone with the back casing facing you and the bottom of the phone towards the sky.
Push down on the cover and slide down to remove. You should only have to apply minimal pressure.
Grasp the edges of the phone with one hand.
Unscrew the six 5.0-mm Phillips #000 screws located around the outside of the back panel of the phone.
다른 한 분이 해당 안내서를 완성하였습니다.
