소개
The screens for the LG VX5600 come together as a single unit inside the phone therefore to replace one you will be replacing the other.
필요한 것
Hold your phone with the back casing facing you and the bottom of the phone towards the sky.
Push down on the cover and slide down to remove. You should only have to apply minimal pressure.
Use tweezers to remove the two rubber covers found at the left and right corners below the inside screen.
Use one hand to grasp the phone and prop the inner grey casing up.
Unscrew the two 3.0-mm Phillips #000 screws located in the upper left and right hand corners.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 한 개
just swapped screens Perfect. step 5 is harder than it look but take time and go easy, I used a 1/8 in blade screwdriver.
