이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Hold your phone with the back casing facing you and the bottom of the phone towards the sky.
Push down on the cover and slide down to remove. You should only have to apply minimal pressure.
Insert your finger into the small indentation above the battery.
Push down on the battery and pull it away from the phone; it will pop out.
Use tweezers to remove the two rubber covers found at the left and right corners below the inside screen.
Grasp the phone and rotate it 90 degrees counterclockwise for a better grip.
Unscrew the two 3.0-mm Phillips #000 screws, found under the rubber covers at the bottom left and right corners.
Hold the opened phone upright.
Use the spudger to pry around the edges of the phone and detach the tabs.
Use your finger to lift up the grey plastic cover.
Use the tweezers to grasp the plastic screen, and pull the plastic screen protector up and out of the phone.
다른 한 분이 해당 안내서를 완성하였습니다.
