주요 콘텐츠로 건너뛰기
LG VX6100 Battery Replacement
필요한 것
  1. LG VX6100 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Open the battery casing by pressing the gray "PUSH" button. Slide the back of the casing downward.
    • Carefully remove the faulty battery from the back of the phone.
    • Inspect the battery port to ensure the battery is the issue. Ensure the four gold connecting prongs are intact and are pointing straight into the port.
  2. LG VX6100 Battery Replacement: 3 단계, 이미지 1/1
    • Align the gold prongs with the gold plates on the bottom of the battery. Make sure "This Side Up" is visible
    • Push the battery flat against the back of the phone until it clicks into place.
    • Replace the back cover of the phone by sliding the casing down into place. Gently press the top until it clicks.
    • Charge the device and turn it on to confirm the issue is resolved.
결론
If after completing the replacement, the device still does not operate properly, further troubleshooting must be done to find and solve the issue.
Eric Funsten
회원 가입일: 04/17/12
1 평판
안내서 3개 작성하였습니다
Cal Poly, Team 12-39, Regan Spring 2012 Cal Poly, Team 12-39, Regan Spring 2012 회원
CPSU-REGAN-S12S12G39
3 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 797
