주요 콘텐츠로 건너뛰기
LG VX7000 Charger Adapter Replacement
필요한 것
  1. LG VX7000 Charger Adapter Replacement, Battery: 1 단계, 이미지 1/1
    • Lay the phone, screen side down, in your palm.
    • Slide the grey button towards the top of the phone.
  2. LG VX7000 Charger Adapter Replacement: 2 단계, 이미지 1/1
    • With the button unlocked, grab the battery on the sides and pull up, then slide the battery up to completely remove it from the phone.
  3. LG VX7000 Charger Adapter Replacement, Motherboard: 3 단계, 이미지 1/1
    • Use the Phillips #00 and remove the four screws on the lower backside of the phone.
    • Remove the three rubber screw covers with tweezers and then the three screws underneath using a Phillips #00 screwdriver.
  4. LG VX7000 Charger Adapter Replacement: 4 단계, 이미지 1/1
    • Detach the outer casing from the back of the phone.
    • There will be a significant amount of resistance to detaching the back casing.
  5. LG VX7000 Charger Adapter Replacement: 5 단계, 이미지 1/1
    • Unsnap the gold rectangular connector and silver square connector from the motherboard.
  6. LG VX7000 Charger Adapter Replacement: 6 단계, 이미지 1/1
    • Remove the motherboard. Do not remove other components.
    • Insert the new motherboard with the white side facing down.
    • Make sure the side buttons on motherboard are correctly aligned to avoid future complications.
  7. LG VX7000 Charger Adapter Replacement, Charger Adapter: 7 단계, 이미지 1/1
    • Replace logic board to replace charging adapter.
결론
Nichole Shaw
회원 가입일: 04/13/10
1 평판
안내서 7개 작성하였습니다
Cal Poly, Team 18-75, Johann Spring 2010 Cal Poly, Team 18-75, Johann Spring 2010 회원
CPSU-JOHANN-S10S18G75
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 2,499
