주요 콘텐츠로 건너뛰기
LG VX7000 External LCD Display Replacement
필요한 것
  1. LG VX7000 External LCD Display Replacement, External LCD Display: 1 단계, 이미지 1/1
    • Using a pair of tweezers, remove the rubber screw covers located at each corner of the main screen.
    • NOTE: There will be a total of four rubber screw covers removed.
    • Turn the screwdriver counterclockwise to unscrew the screws located under the recently removed rubber plugs.
    • NOTE: The screws can not be completely removed from their holes.
  2. LG VX7000 External LCD Display Replacement: 2 단계, 이미지 1/1
    • Using the "iPod Opening Tool", separate the faceplate from the front of the phone.
    • NOTE: There will be a significant amount of resistance when separating the faceplate from the phone.
    • Align the new faceplate in the place of the previously cracked faceplate, and press the new faceplate onto the phone.
결론
Nichole Shaw
회원 가입일: 04/13/10
1 평판
안내서 7개 작성하였습니다
Cal Poly, Team 18-75, Johann Spring 2010 Cal Poly, Team 18-75, Johann Spring 2010 회원
CPSU-JOHANN-S10S18G75
4 회원들
안내서 14개 작성하였습니다
댓글 한 개
My phone turns on but the screen is black I think because one side of the phone the is broken where you flip it open it opens but you just can't see the screen
chayp62 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,688
