주요 콘텐츠로 건너뛰기
LG VX7000 Internal LCD Screen Replacement
필요한 것
  1. LG VX7000 Internal LCD Screen Replacement, Internal LCD Screen: 1 단계, 이미지 1/1
    • Using Tweezers, remove 4 rubber screw covers.
    • Remove screws located under rubber plugs using the screwdriver by turning counterclockwise.
    • NOTE: Screws will not come completely out of phone.
  2. LG VX7000 Internal LCD Screen Replacement: 2 단계, 이미지 1/1
    • Using the iPod Opening Tool, pry the face plate off the front of the phone.
    • NOTE: There will be a significant amount of resistance to removing the face plate from the phone.
  3. LG VX7000 Internal LCD Screen Replacement: 3 단계, 이미지 1/1
    • Unsnap gold plate from the secondary logic board.
    • Reposition the plate so that it is out of the way for face plate removal.
  4. LG VX7000 Internal LCD Screen Replacement: 4 단계, 이미지 1/1
    • Twist upper half of face plate in order to release it from the hinge.
    • Using tweezers detach the speaker and the secondary battery from the faceplate, leaving wires attached.
  5. LG VX7000 Internal LCD Screen Replacement: 5 단계, 이미지 1/1
    • Align new face plate in correct orientation in order to install.
결론
Nichole Shaw
회원 가입일: 04/13/10
1 평판
안내서 7개 작성하였습니다
Cal Poly, Team 18-75, Johann Spring 2010 Cal Poly, Team 18-75, Johann Spring 2010 회원
CPSU-JOHANN-S10S18G75
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 2,219
