이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Using Tweezers, remove 4 rubber screw covers.
Remove screws located under rubber plugs using the screwdriver by turning counterclockwise.
Using the iPod Opening Tool, pry the face plate off the front of the phone.
Unsnap gold plate from the secondary logic board.
Reposition the plate so that it is out of the way for face plate removal.
Twist upper half of face plate in order to release it from the hinge.
Using tweezers detach the speaker and the secondary battery from the faceplate, leaving wires attached.
