주요 콘텐츠로 건너뛰기
LG VX8300 Battery Replacement
  1. LG VX8300 Battery Replacement, Battery Replacement: 1 단계, 이미지 1/3 LG VX8300 Battery Replacement, Battery Replacement: 1 단계, 이미지 2/3 LG VX8300 Battery Replacement, Battery Replacement: 1 단계, 이미지 3/3
    • Power off the device by holding down the power button.
    • Remove the battery cover by pushing down on the solid lines at the top of the cover. Then simply slide the cover down till it is completely removed.
  2. LG VX8300 Battery Replacement: 2 단계, 이미지 1/3 LG VX8300 Battery Replacement: 2 단계, 이미지 2/3 LG VX8300 Battery Replacement: 2 단계, 이미지 3/3
    • Place your finger into the semicircle gap at the top of the battery, then push down and pull so the battery pops out.
  3. LG VX8300 Battery Replacement: 3 단계, 이미지 1/1
    • Wipe down the battery compartment to remove any debris or battery acid. Avoid contact with battery acid as it can damage your eyes or skin.
  4. LG VX8300 Battery Replacement: 4 단계, 이미지 1/1
    • Insert the new Lithium Ion 3.7V 1100mAh battery into the compartment.
결론
After you finish replacing the battery make sure you put the battery cover back on and you will be all set.
nvalm
회원 가입일: 03/23/15
448 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 3-7, Duarte Spring 2015 UMass Dartmouth, Team 3-7, Duarte Spring 2015 회원
UMASSD-DUARTE-S15S3G7
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 501
