주요 콘텐츠로 건너뛰기
LG VX8350 Repair Keypad Removal
필요한 것
  1. LG VX8350 Repair Keypad Removal, Battery: 1 단계, 이미지 1/2 LG VX8350 Repair Keypad Removal, Battery: 1 단계, 이미지 2/2
    • Locate the horizontal grip located on the back cover of the phone.
    • Slide the back cover down and off of the phone.
  2. LG VX8350 Repair Keypad Removal: 2 단계, 이미지 1/2 LG VX8350 Repair Keypad Removal: 2 단계, 이미지 2/2
    • Insert a plastic opening tool into the battery release point located above the battery.
    • Pull outwards in order to release the battery.
  3. LG VX8350 Repair Keypad Removal, Circuit Board Housing: 3 단계, 이미지 1/3 LG VX8350 Repair Keypad Removal, Circuit Board Housing: 3 단계, 이미지 2/3 LG VX8350 Repair Keypad Removal, Circuit Board Housing: 3 단계, 이미지 3/3
    • Locate the 5 screws holding the body of the phone together.
    • The top screw will have a plastic cover, remove it using tweezers.
    • Using a Philips head screwdriver, twist counterclockwise to remove the screws.
    • Take special care with the screw located at the top of the phone. It is smaller and more likely to be damaged or improperly attached.
  4. LG VX8350 Repair Keypad Removal: 4 단계, 이미지 1/2 LG VX8350 Repair Keypad Removal: 4 단계, 이미지 2/2
    • Lift the back cover starting at the bottom of the phone.
  5. LG VX8350 Repair Keypad Removal: 5 단계, 이미지 1/2 LG VX8350 Repair Keypad Removal: 5 단계, 이미지 2/2
    • Remove the back cover completely from the phone.
  6. LG VX8350 Repair Keypad Removal, Circuit Board: 6 단계, 이미지 1/1
    • Locate the clamp at bottom right side of the Circuit Board.
    • Pull the circuit board from the phone being cautious to pull out underneath the clamp.
  7. LG VX8350 Repair Keypad Removal: 7 단계, 이미지 1/2 LG VX8350 Repair Keypad Removal: 7 단계, 이미지 2/2
    • Locate the ribbon connecting the circuit board to the phone display.
    • Using the spudger, disconnect the ribbon connecting the phone's display and the circuit board.
    • Remove the circuit board
  8. LG VX8350 Repair Keypad Removal, Keypad: 8 단계, 이미지 1/2 LG VX8350 Repair Keypad Removal, Keypad: 8 단계, 이미지 2/2
    • Lift the keyboard and remove it from the phone.
결론
James Brandon
회원 가입일: 10/18/13
201 평판
안내서 2개 작성하였습니다
Clemson, Team 14-7, Benson Fall 2013 Clemson, Team 14-7, Benson Fall 2013 회원
CLEM-BENSON-F13S14G7
3 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 277
