필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Locate the horizontal grip located on the back cover of the phone.
Slide the back cover down and off of the phone.
Insert a plastic opening tool into the battery release point located above the battery.
Pull outwards in order to release the battery.
이 단계에 사용된 도구:Tweezers$4.99-
Locate the 5 screws holding the body of the phone together.
Using a Philips head screwdriver, twist counterclockwise to remove the screws.
Take special care with the screw located at the top of the phone. It is smaller and more likely to be damaged or improperly attached.
Locate the clamp at bottom right side of the Circuit Board.
Pull the circuit board from the phone being cautious to pull out underneath the clamp.
Locate the ribbon connecting the circuit board to the phone display.
Using the spudger, disconnect the ribbon connecting the phone's display and the circuit board.
Remove the circuit board
Locate the two rubber circles covering the screws.
Remove the rubber covers using tweezers.
Using the Phillips head screwdriver, unscrew and remove the two screws.
Close the phone and gently pull outwards from the bottom left portion of the phone cover.
Completely remove the cover from the phone.
