주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG VX8550 Camera Replacement
필요한 것
  1. LG VX8550 Camera Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Slide the battery release up.
  2. LG VX8550 Camera Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the battery by lifting away from the case.
  3. LG VX8550 Camera Replacement, Case: 3 단계, 이미지 1개 중 1개
    • Remove the 2 screw covers next to the rear speaker with a Push Pin.
  4. LG VX8550 Camera Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the 4 cover screws with a Philips #00 screwdriver.
  5. LG VX8550 Camera Replacement: 5 단계, 이미지 1개 중 1개
    • Use the iPod opening tool to pry off the back casing.
  6. LG VX8550 Camera Replacement: 6 단계, 이미지 1개 중 1개
    • Continue sliding the iPod opening tool around the seam of the casing to separate the front and back casings.
  7. LG VX8550 Camera Replacement: 7 단계, 이미지 1개 중 1개
    • Separate the casing halves.
    • Be sure to keep track of the side buttons as they fall out.
  8. LG VX8550 Camera Replacement, Motherboard: 8 단계, 이미지 1개 중 1개
    • Remove the 2 screws from the back of the phone with a Phillips #00 Screwdriver.
  9. LG VX8550 Camera Replacement: 9 단계, 이미지 1개 중 1개
    • Carefully lift up on the motherboard to see the ribbon cables underneath.
    • Use the spudger to carefully disconnect the ribbon cable from the motherboard.
  10. LG VX8550 Camera Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the motherboard from the front casing by lifting straight up.
  11. LG VX8550 Camera Replacement, Keypad Housing: 11 단계, 이미지 1개 중 1개
    • Lay the phone with the screen facedown.
    • The 6 slider screws are visible.
  12. LG VX8550 Camera Replacement: 12 단계, 이미지 1개 중 1개
    • Peel back but don't remove the blue tape to access the 2 center screws.
    • Remove the 6 slider screws with the Phillips #00 screwdriver.
  13. LG VX8550 Camera Replacement: 13 단계, 이미지 1개 중 1개
    • Lift the keypad housing away from the slider.
  14. LG VX8550 Camera Replacement, Front Case: 14 단계, 이미지 1개 중 1개
    • Remove the 2 screw covers next to the speaker with a push pin next to the camera.
  15. LG VX8550 Camera Replacement: 15 단계, 이미지 1개 중 1개
    • Remove the 6 screws with a Phillips #00 Screwdriver.
  16. LG VX8550 Camera Replacement: 16 단계, 이미지 1개 중 1개
    • Use the ipod opening tool to pry the screen casing and the slider mechanism apart from each other.
  17. LG VX8550 Camera Replacement: 17 단계, 이미지 1개 중 1개
    • Carefully lift the slider mechanism to see the ribbon cables underneath.
  18. LG VX8550 Camera Replacement: 18 단계, 이미지 1개 중 1개
    • Slide ribbon cable through the slider mechanism.
  19. LG VX8550 Camera Replacement: 19 단계, 이미지 1개 중 1개
    • Separate the two halves.
  20. LG VX8550 Camera Replacement, Camera: 20 단계, 이미지 1개 중 1개
    • With the screen casing separated from the slider mechanism the camera circuit board is visible.
    • Carefully lift up on the connector to unplug it from the circuit board.
  21. LG VX8550 Camera Replacement: 21 단계, 이미지 1개 중 1개
    • Lift up slowly on the connector cable to peel the camera off the adhesive backing.
  22. LG VX8550 Camera Replacement: 22 단계, 이미지 1개 중 1개
    • Remove camera from the casing.
결론
작성자
4다른 기여자 명과 함께
Nathan Jones
회원 가입일: 04/10/10
89 평판
안내서 10개를 작성함
Cal Poly, Team 34-55, Forte Spring 2010 Cal Poly, Team 34-55, Forte Spring 2010 회원
CPSU-FORTE-S10S34G55
5 회원들
안내서 22개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 15
지난 30일: 73
전체 시간: 1,677
