주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
Steps to replace the LG VX8550 motherboard
  1. Slide the battery release up.
    • Slide the battery release up.
  2. Remove the battery by lifting away from the case.
    • Remove the battery by lifting away from the case.
  3. Remove the 2 screw covers next to the rear speaker with a Push Pin.
    • Remove the 2 screw covers next to the rear speaker with a Push Pin.
  4. Remove the 4 cover screws with a Philips #00 screwdriver.
    • Remove the 4 cover screws with a Philips #00 screwdriver.
  5. Use the iPod opening tool to pry off the back casing.
    • Use the iPod opening tool to pry off the back casing.
  6. Continue sliding the iPod opening tool around the seam of the casing to separate the front and back casings.
    • Continue sliding the iPod opening tool around the seam of the casing to separate the front and back casings.
  7. Separate the casing halves.
    • Separate the casing halves.
    • Be sure to keep track of the side buttons as they fall out.
  8. Remove the 2 screws from the back of the phone with a Phillips #00 Screwdriver.
    • Remove the 2 screws from the back of the phone with a Phillips #00 Screwdriver.
  9. Carefully lift up on the motherboard to see the ribbon cables underneath.
    • Carefully lift up on the motherboard to see the ribbon cables underneath.
    • Use the spudger to carefully disconnect the ribbon cable from the motherboard.
  10. Remove the motherboard from the front casing by lifting straight up.
    • Remove the motherboard from the front casing by lifting straight up.
결론
Nathan Jones
회원 가입일: 2010년 04월 10일
89 평판
안내서 10개 작성하였습니다
Cal Poly, Team 34-55, Forte Spring 2010 Cal Poly, Team 34-55, Forte Spring 2010 회원
CPSU-FORTE-S10S34G55
5 회원들
안내서 20개 작성하였습니다
It is a nice way to remove the motherboard of the LG mobile i did not done it but your have done it very nicely and with a great way. thanks for this good post i really enjoy the reading.
http://harrypotter1081.livejournal.com/
Harry Potter - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 2,405
