주요 콘텐츠로 건너뛰기
LG VX8550 Motherboard Replacement
필요한 것
  1. LG VX8550 Motherboard Replacement, Battery: 1 단계, 이미지 1/1
    • Slide the battery release up.
  2. LG VX8550 Motherboard Replacement: 2 단계, 이미지 1/1
    • Remove the battery by lifting away from the case.
  3. LG VX8550 Motherboard Replacement, Case: 3 단계, 이미지 1/1
    • Remove the 2 screw covers next to the rear speaker with a Push Pin.
  4. LG VX8550 Motherboard Replacement: 4 단계, 이미지 1/1
    • Remove the 4 cover screws with a Philips #00 screwdriver.
  5. LG VX8550 Motherboard Replacement: 5 단계, 이미지 1/1
    • Use the iPod opening tool to pry off the back casing.
  6. LG VX8550 Motherboard Replacement: 6 단계, 이미지 1/1
    • Continue sliding the iPod opening tool around the seam of the casing to separate the front and back casings.
  7. LG VX8550 Motherboard Replacement: 7 단계, 이미지 1/1
    • Separate the casing halves.
    • Be sure to keep track of the side buttons as they fall out.
  8. LG VX8550 Motherboard Replacement, Motherboard: 8 단계, 이미지 1/1
    • Remove the 2 screws from the back of the phone with a Phillips #00 Screwdriver.
  9. LG VX8550 Motherboard Replacement: 9 단계, 이미지 1/1
    • Carefully lift up on the motherboard to see the ribbon cables underneath.
    • Use the spudger to carefully disconnect the ribbon cable from the motherboard.
  10. LG VX8550 Motherboard Replacement: 10 단계, 이미지 1/1
    • Remove the motherboard from the front casing by lifting straight up.
결론
Nathan Jones
회원 가입일: 04/10/10
89 평판
안내서 10개 작성하였습니다
Cal Poly, Team 34-55, Forte Spring 2010 Cal Poly, Team 34-55, Forte Spring 2010 회원
CPSU-FORTE-S10S34G55
5 회원들
안내서 20개 작성하였습니다
댓글 한 개
It is a nice way to remove the motherboard of the LG mobile i did not done it but your have done it very nicely and with a great way. thanks for this good post i really enjoy the reading.
http://harrypotter1081.livejournal.com/
Harry Potter - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 2,477
