이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Steps to remove the LG VX8550 scroll wheel
필요한 것
Remove the 2 screws from the back of the phone with a Phillips #00 Screwdriver.
Remove the 2 screw covers next to the speaker with a push pin next to the camera.
With the spudger, lift up under the connector to unplug it from the circuit board.
Carefully lift the circuit board away from the screen casing using Ipod Opening Tool.
Peel the circuit board away from the adhesive backing with your finger.
다른 한 분이 해당 안내서를 완성하였습니다.
