이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Continue sliding the iPod opening tool around the seam of the casing to separate the front and back casings.
Remove the 2 screws from the back of the phone with a Phillips #00 Screwdriver.
Carefully lift up on the motherboard to see the ribbon cables underneath.
Use the spudger to carefully disconnect the ribbon cable from the motherboard.
Lay the phone with the screen facedown.
The 6 slider screws are visible.
Peel back but don't remove the blue tape to access the 2 center screws.
Remove the 6 slider screws with the Phillips #00 screwdriver.
Remove the 2 screw covers next to the speaker with a push pin next to the camera.
Use the ipod opening tool to pry the screen casing and the slider mechanism apart from each other.
With the slider mechanism separated from the screen casing the 8 screws securing the slider mechanism are visible.
Remove the 8 screws.
Remove slider mechanism. Now is a good time to clean slider mechanism if sticky.
다른 한 분이 해당 안내서를 완성하였습니다.
